ILLANVIETTOA JA TÄYSIN JOUTAVAA TURINAA ( osa II )
Tässä on etäisesti jotain tuttua:
For all of the great aspects of the Cummins N14 its Achilles Heel has always been the injectors. The L10, M11 and N14 all have problems with injector failures and the surrounding electronics. The fuel system’s main components consists of the injectors, injector wiring harness and the ECM. A common occurrence will happen when, for example, when the ECM shows a 111 or 343 code in an N-14 Celect Plus model. This means the ECM isn’t grounded to the injector. Usually this starts out with only 1 injector shown to be malfunctioning but can quickly spread to others. If this happens you immediately want to shut down the engine.
These early electronic engines offered no protection against the wiring harness shortening out. There are 6 injector driver connections on the ECM which are attached to the injectors via a wiring harness. If an injector goes bad it is advised to pull out the wiring from the injector and replace immediately before the faulty wire burns up the ECM motherboard. Usually if you unplug # 1, 2, 3, or 4 injector drivers in time you can save the ECM/injectors. The wiring harnesses are known to have problems and are very expensive to replace.
Another issue with the N14 ECM is a faulty fuel solenoid. The solenoid is situated on the bottom of the ECM. If the solenoid shorts it will heat up the ECM slowly and can then destroy the entire fuel solenoid circuit, memory chip and the injector timing chip. Usually the solenoid gets so hot it melts the solder on the chips. For a 50 pin connection all it takes is one pin to loosen from the heat to destroy the ECM. It is recommended that drivers carry 1-2 extra injectors in the truck in case one goes out. Usually they go out in pairs which makes sense to carry 2 at all times.
Ei tosin Mersussa tarvi kantaa ylimääräisiä suuttimia eikä hikoilla johtosarjavikojen kanssa. Mut boksin sisäisistä suojauksista huolimatta niille voi toisinaan käydä huonostikin... Tai tälleen oon jostain lukenut.
(lähde: https://www.capitalremanexchange.com/cummins-n14-specs-history-problems/)
Ei oo mukana kannettu suuttimia eikä taisteltu moottorin johtosarjojen kanssa , vielä...
18.8.2022 klo 11:11 - YxJampe: Mörr
18.8.2022 klo 16:21 - AJS: ÖRR
18.8.2022 klo 16:44 - klappi: Jos vaikka vähän haihaiörröä
18.8.2022 klo 17:36 - AJS: kuuma
18.8.2022 klo 17:36 - AJS: kostea
18.8.2022 klo 17:36 - AJS: paskailma siis
18.8.2022 klo 18:11 - klappi: Vauhtia lisää niin tarkenee
18.8.2022 klo 19:04 - AJS: .
18.8.2022 klo 19:16 - AJS: https://www.loviisansanomat.fi/paikalliset/4793408
18.8.2022 klo 21:00 - klappi: Nelgeetquus
18.8.2022 klo 21:01 - klappi: +24 jo aika passeli potkia
Jossakin maksumuurissa tuokin ilmastopieru, mutta kovin alkaa korkeelta mielestäni ensiauton hinnat, nolla jokaisesta luvusta pois :rolleyes:
Ihmaalliin tapaus täs läheisellä Pitkänsillantiellä, oli kaverini kaverin pysäyttäneet kaksi hoono soomi miestä tukkimalla tien, olivat kyselleet kenellä on avantti täällä? tämä henkilö ei tiennyt, eikä olisi neuvvonut vaikka olisi tiennytkin avantin omistajia. Oli siis jo liki iltaysi. Suomen kilvissä oli vetoauto ja jarrulliin kärry, numerot on muistissa. Kaveri soitti mulle että tiedänkö avantin omistajia. Siellä on maansiirtoliike mutta soiton perusteella heillä ei ole avantteja, eikä kuullemma tule. Toisella yksityishenkilöllä on rikkinäinen avantti mitä hän ei eesoo myymässä. Saa kuullemma tulla yrittämään pöllimistä. Tontilla (aidatulla) on kaks urossaksaria vapaana. Minäkään en veräjästä uskalla mennä enneskun soitan. Ihme hiippareita taas.
Kyrvän salassa, eiku Sarvan kylässä tapahtuu aina ihmeellisiä asioita. Tänäänkin näky olleen lehessä taas juttua. Perintötilan omistaja oli menossa muutama vuos sitten hakennu kallioaineksen louhintalupaa mailleen, lupa kaatui kun kaikki kylän asukkaat vastusti sitä. Mökkiläise etenkin. Toisekseen tienpohja ei ois korjaamatta kestänny sitä murskerallia vahvistamatta. Hän ja Isänsä ovat itte myyneet nämä rantapalstat. Nyt oli pari vuotta sitten kaivannu veräjän portin pylvään pois mökkiläiseltä kun oli kuullemma puoliks hänen maillaan.. Toissa juhannuksena oli sit kaivinkoneella juhannusaattona raappinnu rajanaapurinsa pensasaitaa pois kun on istutettu hänen mailleen.. Joutu sit soittaan polliisit ite paikalle kun mökkiläiset meinas "lynkata".. Pylvään poiston oikeudenkäyntikulut tuli maksaan yli kymppitonnin ja valittaa asiasta. Pensasaitajuttu kans oikeuteen. +muita vastaavia. Että 69v mies viittii. -80 luvulla Karpo julkaisi pätkän. Vesijärveä laskettiin vajaan 3m 1900 luvun alussa kun vääksyn kanava tehtiin. Osa oli lunastanut vesijätön, osa ei. Tämä mainittu henkilö kävi sitten lunastamattomien vesijätön tonteille virittämässä lippusiiman vanhan vedenkorkeuden mukaan "että tämän lähemmäks" rantaa ei oo asiaa. Jokunen rantasauna ja laituri oli sitten "kiellettyä aluetta". En muista miten juttu päättyi, enkä nyt sitä pengo. Nyt voitten ymmärtää mistä tämä kauna. Ko. "miehen" olen tuntennu koko ikäni ja meillä ei ole koskaan ollu riitoja. Tosin asun naapurikylässä 10km päässä.
On niitä laitureita ja rantasaunoja siirretty vesijätöiltä kun eivät ole halunneet lunastaa sitä. Sitte se ei enään olekkaan rantatontti....
Jos ei kiinteistön omistaja halua lunastaa, voiko sen ostaa joku muu?
Joissain paikoin on loivat rannat niin ehkä siitä vois ostaa "rantatontin".. No, kuivan maan tontilla asun niin ei "rantatontit" kiinnosta.. Mitenkähän siellä Höytiäsissä vesijättömaitten kävi?
Ostinpa 3kg kukkakaalin tänään, sit piti kotona ettii kattila missä mahtuu keittään.. Kantta en löytänny mut kai sen voi keittää ilmankin. karkee suola just riitti mut tallissa on 25kg säkki puolillaan. Isukkivainaan heinäsuolia. Joku frouvva repi ne vihreet lehden jämät pois, lattialle kun ei ollu astiaa vieressä.. Kyllä minä syön lehtineen, lehdet kuuluu kukkakaaliin. 7v sitten kun tuli viikoittaan bussilla liikuttua Lahti-Kangasala väliä nii hauhon seutuvilla oli kukkakaalipeltoja. Porukkaa oli keräämässä niitä "kauppakokosia". Murskaimellaa sit vetivät syssymmälä tantereeseen.. Kyllä mulle ois maistunnu..
Tjuotanoin .... Olisko jotain aihetta käyttää pitkähihaista paitaa, tai jotain takkia, tiggaillessa alumiinii 100+ A virroilla .....
