Wikipediassa oli lueteltu joitain tuon prosessin haittoja:
Friction drilling is not possible in massive material since displaced metal must be able to flow somewhere. Maximum material thickness is typically half of the hole diameter[4] with bit manufacturers providing specific guidance.[5]
The target material must be able to withstand the added heat. Materials that have been painted, plastic coated, galvanized, or heat treated are often unsuitable for this process.
Requires higher motor capacity and rotational speed than conventional drills.[2]
Suurpiirteinen käännös olisi:
Maksimi materiaalivahvuus tyypillisesti puolet reiän halkaisijasta.
Kohdekappale kuumenee prosessissa
Vaatii enemmän kierroksia ja tehoja kuin tavallinen poraus
